Whether stand-alone or as a part of your extended fleet, the Xerox VersaLink B405 multifunction printer take your team to high levels of productivity. Work the way you want - from any device - with maximum security and easy connectivity to and from both cloud and network-based locations.
Easy, optimized productivity
Right out of the box, you'll count on your Xerox VersaLink B405 multifunction printer to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. And count on day in, day out reliability thanks to the paper path technology. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. Ensure information accuracy with Scan and Fax preview, and do more with scanned documents with built-in optical character recognition (OCR). Print with total peace of mind knowing that VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access. -
An entirely advanced way to work
With the customizable 5-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox ConnectKey apps help optimize office efficiency. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy access to task-specific presets and commonly used apps on a personalized home screen. -
Touch screen superiority
The tiltable, 5-inch capacitive color touch screen is the user interface that sets a higher standard for customization, personalization and versatility. By presenting a familiar "mobile" experience - with support for gestural input and task-focused apps that share a common look and feel - fewer steps are needed to complete even the most complex jobs. A highly intuitive layout guides you through every task from start to finish, with a natural hierarchy placing critical functions near the top of the screen and commonly used options front and center.
- Xerox VersaLink B405V/DN - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 110000 pages
- Recommended Monthly Volume
- 12000 pages
- Max Copying Speed
- Up to 36 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 45 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 600 x 600 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 60 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Standard Media Capacity
- 700 sheets
- Max Media Capacity
- 1250 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- Gigabit LAN, NFC, USB 3.0
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 49.5 cm x 49.5 cm x 55.1 cm
- 22 kg
- Fax Type
- Plain paper
- Laser - monochrome
- 110000 pages
- 12000 pages
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
Copying
- Max Copying Speed
- Up to 36 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- ID Card Copy, Edge Erase, Book Copy
Printing
- Up to 45 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, JPEG
- First Print Out Time B/W
- 5.1 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- 600 x 600 dpi
Document & Media Handling
- Min Original Size
- 76.2 x 127 mm
- Max Original Size
- 60 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- 700 sheets
- 1250 sheets
- 250 sheets
- RADF - 60 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) weight: 60 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets , Input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Speed Details
- Printing: up to 45 ppm (Letter A) - B/W , Printing: up to 45 ppm (A4) - B/W
- 1 x USB 3.0 , 1 x Gigabit LAN
- Secure Print, TLS, Secure Fax, Secure Scan, Secure Email
- Software Included
- Xerox CentreWare Web
- Voltage Required
- 620 watt
- Power Consumption Standby
- 60 watt
- Power Consumption Sleep
- 4 watt
- First Copy Out Time B/W
- 6.2 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 5900 pages
- FIPS 140-2
- 49.5 cm
- 49.5 cm
- 55.1 cm
- 22 kg
- Shipping Width
- 61.8 cm
- Shipping Depth
- 62.6 cm
- Shipping Height
- 71.3 cm
- Shipping Weight
- 27.1 kg
- Sound Emission
- 52.3 dBA (idle) / 28.7 dBA (operating)
- 10 °C
- 32 °C
- 10 - 85%
Xerox Standard Capacity Black Toner Cartridge (6000 Pages) | In Stock | £155.22 |
Xerox Extra High Capacity Black Toner Cartridge (25000 Pages) | In Stock | £356.96 |
