Wasp Barcode Technologies WWS850 Bluetooth Wireless Barcode Scanner Kit gives you the freedom to roam. With the WWS850 Barcode Scanner, you can take your scanner to your inventory instead of your inventory to your scanner. The WWS850 Barcode Scanner uses Bluetooth technology, which allows you to scan barcodes and transmit the data up to 160 feet depending on the environment. Scan barcodes from 1 to 25 inches with an aggressive Laser scan engine. The kit comes complete with Bluetooth wireless barcode scanner, Bluetooth radio/recharge base, and cable for the base. Ideal for warehouse, factory floor, field service and retail environments. The Wasp WWS850 Wireless Barcode Scanner supports Microsoft Windows, Microsoft NT, DOS and Macintosh applications.
- Wasp WWS850 Wireless Laser Barcode Scanner Kit - PS2 - barcode scanner
- Barcode scanner - portable - Bluetooth
- Localisation
- United Kingdom
- Connectivity Technology
- Wireless
- Wireless Connectivity
- Bluetooth
- System Requirements
- Microsoft DOS, Apple MacOS, Microsoft Windows 98 Second Edition, Microsoft Windows 95/98/ME/NT/2000/XP
- Localisation
- United Kingdom
Barcode
- Interface Type
- Bluetooth
- Max Working Distance
- 63.5 cm
- Decode Capability
- Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, NW-7, Telepen, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Italy Pharmacode, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey, GS1 DataBar-14
- Wireless
- Reduced Space Symbology (RSS)
- Bluetooth
- 1 x PS/2 keyboard wedge
- Included Accessories
- Cradle
- Cables Included
- 1 x keyboard wedge cable - external
- OS Required
