WASP WRS100SBR Ring Scanner with Charging Cradle
Quicklinx: GB7DWS00 Mfr#: 633809005152
Type: Barcode scanner
Form Factor: Wearable
£159.95 ex VAT
£191.94 inc VAT
The Wasp WRS100SBR Ring Barcode Scanner is a hands-free, ring scanner designed for mobile operators who work with devices such as laptops, tablets, and smartphones. Its ergonomic design includes a double strap to allow operators to wear it on their right or left hand for extended periods of use.
Wasp WRS100 SBR Ring Barcode Scanner - barcode scanner
Barcode scanner - wearable - Bluetooth 4.1 - decoded
Black, yellow
Minimum Bar Width
4 mil
Scan Field Width
13 cm
Scan Element Type
Linear imager
Scan Speed
400 scan / sec
Wireless
Wireless Connectivity
Bluetooth 4.1
1 x lithium polymer
2.76 cm x 4.62 cm x 2.68 cm
20.5 g
Black, yellow
Barcode
Interface Type
Bluetooth 4.1
Minimum Bar Width
4 mil
Scan Field Width
13 cm
Scan Element Type
Linear imager
Light Source Wave Length
650 nm
Scan Speed
400 scan / sec
Max Working Distance
25.5 cm
Skew (Degrees)
40
Pitch (Degrees)
30
Print Contrast Signal (PCS)
30%
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Telepen, Code 32, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, UK-Plessey, EAN-8/13
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
ESD (electrostatic discharge) safe, white LEDs illumination, Human Interface Device Profile (HID)
Bluetooth 4.1
Flash
2 MB
1 x micro-USB to USB cable - external - 1.5 m
FCC Part 15 B, FCC Part 15 C, WEEE, TELEC, FDA, REACH, IP42, RoHS2, EN 300 328, IEC 60825-1 Class 1, EN 301 489-1-17, EN 62479, IEC/EN 60950-1, EN 60825-1 Class 1
Barcode scanner charging stand
1 x lithium polymer
2.76 cm
4.62 cm
2.68 cm
20.5 g
Shipping Width
22.86 cm
Shipping Depth
15.24 cm
Shipping Height
5.08 cm
Shipping Weight
200 g
-10 °C
50 °C
0 - 95% (non-condensing)
Drop Specification
1.5 m
Brand: WASP
