The Wasp WCS3900 barcode scanner series are the most popular CCD barcode scanning devices in the Wasp product line. Manufactured for durability yet employing an exclusive ergonomic design for comfort, the WCS3900 and WCS3905 barcode scanners are the best in their class.
For fast connection, the WCS3900 can simply be plugged into a keyboard wedge via USB or PS/2. Both barcode scanners send data to an active application just like it was typed on a keyboard. They are designed for retail, point of sale, or any repetitive process where time and accuracy are important factors in making business succeed. The WCS3900 CCD barcode scanner is a contact scanner that reads barcodes up to 1" away with a maximum barcode width of 3.25".
An optional stand is available for hands-free scanning applications.
- Wasp WCS3905 CCD Scanner - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Localisation
- United Kingdom
- Scan Field Width
- 8 cm
- Scan Element Type
- CCD
- Scan Speed
- 45 scan / sec
- Connectivity Technology
- Wired
- 9.2 cm x 18.8 cm x 2.7 cm
- 125 g
- Localisation
- United Kingdom
Barcode
- Interface Type
- USB
- Scan Field Width
- 8 cm
- Scan Element Type
- CCD
- Light Source Wave Length
- 660 nm
- Scan Speed
- 45 scan / sec
- Max Working Distance
- 2.5 cm
- Decode Capability
- Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, ISBN, Code 32, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, China Post, IATA 2 of 5, ISSN, UK-Plessey
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- 1 x USB - Type A
- Cables Included
- 1 x USB cable - external
- FCC Class A certified
- 9.2 cm
- 18.8 cm
- 2.7 cm
- 125 g
- 0 °C
- 50 °C
- 20 - 80%
