The Wasp WLS9600 laser barcode scanner makes it simple to add barcode data to spreadsheets, word processing documents or databases. Just connect the WLS9600 to your PC (USB, RS-232, Keyboard Wedge, IBM 46XX and Wand Emulation), and you're ready to begin scanning barcodes. The WLS9600 features a laser scan engine for rapid, error-free data entry. Easily read all common 1D barcodes, including damaged symbols or stacked RSS barcodes. The WLS9600 offers aggressive reading performance, with over 100 scans per second, and a patented "Green Spot" technology for good-read feedback; making the scanner extremely easy to use. Fast scan rate and dynamic decoding capabilities ensure employees are able to scan items quickly and, as a result, spend less time keying in data.
 - Wasp WLS 9600 Laser Scanner - barcode scanner
 - Barcode scanner - handheld - keyboard wedge - decoded
- Minimum Bar Width
 - 5 mil
- Scan Field Width
 - 3.6 cm - 69 cm
- Scan Element Type
 - Visible laser diode
- Scan Speed
 - 100 scan / sec
- Connectivity Technology
 - Wired
- System Requirements
 - Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
 - 7.1 cm x 18.1 cm x 10 cm
 - 169 g
 - 2-year warranty
Barcode
- Interface Type
 - Keyboard wedge
- Minimum Bar Width
 - 5 mil
- Scan Field Width
 - 3.6 cm - 69 cm
- Scan Element Type
- Light Source Wave Length
 - 630-680 nm
- Scan Mode
 - Single-pass
- Scan Speed
 - 100 scan / sec
- Decode Capability
 - Code 93, GS1 DataBar, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 3 of 9, Interleaved 2 of 5, MSI-Plessey, China Post, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked
- TTL Decoding
 - Decoded
 - Wired
 - Reduced Space Symbology (RSS), Green Spot technology
 - 1 x keyboard wedge
- Cables Included
 - 1 x keyboard wedge cable - 1.83 m
 - IEC 60825-1, CDRH Class II
- Electric Current Required
 - 260 mA (operating)
- OS Required
 - 7.1 cm
 - 18.1 cm
 - 10 cm
 - 169 g
 - Limited warranty - 2 years , Technical support - unlimited
 - 0 °C
 - 55 °C
 - 5 - 90% (non-condensing)
- Drop Specification
 - 1.8 m to concrete
