WASP WPL205 Desktop Barcode Printer
Quicklinx: 7FL9WS00 Mfr#: 633808503826
The Wasp WPL205 is a compact, powerful desktop barcode printer designed to meet your light- to medium-duty barcode printing requirements. It is a direct thermal barcode printer that comes complete with a label peeler as well as support for EPL, ZPL and WPL printer modes.
Direct thermal printers like the WPL205 are ideal for creating barcode labels that have a shorter life span such as shipping labels for product packages and containers. Direct thermal uses heat to interact with the label paper to create an extremely high quality label that includes text and barcodes.
Conveniently sized with a clamshell design that makes loading media a snap, this easy-to-use printer provides all you need in a direct thermal desktop printer. This value packed printer also includes an integrated peeler, which the speeds the application of labels to packages. The WPL205 prints at speeds up to 5 inches per second at 203 dpi print resolution. Due to its reliability, it requires little maintenance. WPL205 thermal printers are CE, FCC, TUV, and UL certified.
Wasp WPL205 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
2 kg
Max Media Size
Roll (11.2 cm)
Max Media Size (Custom)
112 mm
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 dpi
Parallel, USB, serial
RAM Installed (Max)
2 MB
Flash Memory Installed (Max)
2 MB
Language Simulation
ZPL, EPL
Barcodes
Code 93, Code 39, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, China Post, EAN-UCC Composite, EAN-14, ITF-14
Media Type
Labels, continuous forms, fanfold paper, paper tag
Peeler
Total Media Capacity
1 roll
Microsoft Windows NT, Microsoft Windows 98/ME/2000/XP
20 cm x 24 cm x 16.4 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 127 mm/sec - 203 dpi
Built-in Devices
Peeler
Wired
203 dpi
Language Simulation
ZPL, EPL
Peeler
Barcodes
RAM
RAM Installed (Max)
2 MB
Flash Memory
Flash Memory
2 MB
Media Handling
Media Type
Max Media Size
Roll (11.2 cm)
112 mm
Media Sizes
Roll (1.9 cm), Roll (11.2 cm)
Max Printing Width
108 mm
Max Printing Length
999 mm
Media Thickness Range
0.06 mm - 0.19 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 76.2 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (11.2 cm)
Expansion Slots
1 x parallel , 1 x serial , 1 x USB
Consumables Included
1 x ribbon
UL, TUV GS, C-Tick, BSMI, cUL, CCC, FCC
Power adapter - external
5 °C
25 - 85%
20 cm
24 cm
16.4 cm
2 kg
