WASP CCD Keyboard Wedge Scanner for PC
Customer rating: 1.0* (Write a review)
Quicklinx: 2NJ6WS00 Mfr#: 633808501051
Wasp Bar Code CCD Scanner is the most popular solution for scanning bar codes. Its ease-of-use and durability make the CCD a favorite with customers. Wasp Bar Code CCD Scanner simply plugs between your keyboard and computer. This Scanner allows you to scan into any Windows, DOS, NT, or Mac application. Automate your data collection tasks with this easy-to-use, one-touch scanner.
Wasp CCD Scanner - barcode scanner
Barcode scanner - handheld - keyboard wedge
Scan Element Type
CCD
Scan Speed
50 scan / sec
Wired
Microsoft DOS, Microsoft Windows 3.x/95/98, Microsoft Windows NT, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP
8.3 cm 19.1 cm
0.2 kg
Barcode
Interface Type
Keyboard wedge
Scan Element Type
CCD
Light Source Wave Length
660 nm
Scan Mode
Hand-held
Scan Speed
50 scan / sec
Decode Capability
Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey
Wired
1 x keyboard
1 x keyboard cable - 2.4 m
FCC Class A certified
8.3 cm
19.1 cm
0.2 kg
50 °C
20 - 85%
Customer reviews
Write a review for the WASP CCD Keyboard Wedge Scanner for PC here!
don't bother
Reviewed by chris brown. Review Posted 02/02/2006
takes multiple attempts to scan even large high quality barcodes - not a chance if the barcode is slightly damaged. Sometimes the keyboard stops working after restarting the computer.
  • Overall 1*
  • Ease of use 1*
  • Value for money 2*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
