Vision Professional Dual Monitior Desk Post Mount White
Quicklinx: F4QKWS00 Mfr#: VFM-DPD2W+S
Correct ergonomics are essential to avoid injury and maximize productivity.
  • Versatile adjustments
    With height, rotation, swivel, and tilt adjustments, this mounting kit offers flexibility, allowing users to find the perfect viewing angle for comfort and productivity.
  • Comprehensive cable management
    Equipped with cable clips on the bar, the design ensures a tidy workspace by neatly organizing and concealing cables, enhancing both functionality and aesthetics.
  • Robust construction
    Crafted from steel with a powder-coated finish, this mounting kit provides durability and stability, ensuring your devices are securely positioned.
  • Easy installation
    The package includes all necessary mounting components such as a 17.4" post, dual articulating arm, and screws, facilitating a hassle-free setup on any desk.
  • Optimal compatibility
    Designed to support LCD displays and notebooks from 13" to 27", along with a VESA interface for 100 x 100 mm and 75 x 75 mm, this kit is compatible with a wide range of devices.
Vision VFM-DPD2W+S mounting kit - for LCD display / notebook - white
Mounting kit - desk-mountable
Mounting Components
Grommet mount, dual articulating arm, 2 VESA adapters, notebook tray, 17.4" post
Tilt
-45° to 45°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
Recommended Use
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Steel
White
Package Content
Screws
Material
Steel
White
Package Content
Screws
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Desk-mountable
Shelf Qty
1
Cable Management
Cable clips on the bar
13"-27"
Tilt
-45° to 45°
Swivel
-90° to 90°
Adjustments
Finish
Powder coated
Dimensions & Weight Details
Dimensions
Notebook shelf - width: 30 cm height: 28 cm
Limited warranty - lifetime
