Dicota Privacy filter 2-Way for Monitor 28 Wide (16:9), side-mounted
Quicklinx: GX4FWS00 Mfr#: D31942
£90.64 ex VAT
£108.76 inc VAT
Protect your data. Secret is a highly effective protective film that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The innovative microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
  • Privacy protection from two sides (left/right)
  • Limits side-to-side vision to ±30°
  • 43% blue light cutting
  • A clear view at all times
  • Accurate colour reproduction
  • Reduces reflections and fingerprints
  • High scratch resistance
  • Matt and glossy side provide optimum visibility in any open space
  • Attached using plastic holders and adhesive points
DICOTA Secret display privacy filter - 28" wide
Display privacy filter - 2-way
Installation Type
Removable - adhesive
Display Screen Size Compatibility
28" wide
Product Material
PET
62.1 cm x 0.038 cm x 34.2 cm
28" wide
Product Material
PET
62.1 cm - 0.038 cm - 34.2 cm
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:9
Scratch Resistant
Anti-glare, anti-reflective, easy-to-remove, fingerprint-proof, 43% blue light cutting
Brand: Dicota
