Dicota Anti-Glare 3H filter for Lenovo ThinkVision T23d, self-adhesive
Quicklinx: G92QWS00 Mfr#: D70368
£38.39 ex VAT
£46.06 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA display anti-glare filter - 22.5"
Display anti-glare filter
Installation Type
Removable - adhesive
Transparent
Display Screen Size Compatibility
22.5"
Product Material
PET
48.4 cm x 0.0155 cm x 30.2 cm
40 g
Lenovo ThinkVision T23d-10
22.5"
Product Material
PET
48.4 cm - 0.0155 cm - 30.2 cm
40 g
Transparent
Display Filter
Installation Type
Scratch Resistant
Anti-reflective, 3H hard-coating, bubble-free installation, fingerprint-proof, silicone layer back, high mechanical resilience, touch capable
Brand: Dicota
