Dicota Privacy filter 2-Way for Lenovo ThinkVision T23d
Quicklinx: G92TWS00 Mfr#: D70371
£77.52 ex VAT
£93.02 inc VAT
Protect your data. Secret is a highly effective protective film that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The innovative micro lamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
DICOTA display privacy filter - 22.5"
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
22.5"
Product Material
PET
48.4 cm x 0.038 cm x 30.2 cm
70 g
Lenovo ThinkVision T23d-10
22.5"
Product Material
PET
48.4 cm - 0.038 cm - 30.2 cm
70 g
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Scratch Resistant
Anti-glare, anti-reflective, blue light cutting, fingerprint-proof, side-mounted, touch capable, plastic holders
Brand: Dicota
