Veho Kasa Bluetooth Smart LED Light Bulb - B22
Quicklinx: CV8YWS00 Mfr#: VKB-003-B22
Enjoy low energy adaptive lighting with the Kasa smart lighting Bluetooth wireless LED bulbs. Automate your home lighting wirelessly through the Kasa app for iOS and Android.
The Kasa smart lighting B22 Bluetooth 7.5 watts (40 watts converted) LED bulb will give you 15,000 hours of adaptive low energy lighting. Kasa Bluetooth bulbs have a cost efficient life expectancy of 15 years when used 3 - 4 hours per day.
In conjunction with the Kasa smart lighting app for iOS and Android you can enable a world of adaptive and creative lighting while automating you home lighting through the power of your smartphone or tablet.
With white or yellow light hue and 16 million dimmable colours available, you can preset groups of rooms or moods so that you can control and adapt the lighting of your home environment at the touch of your smartphone or tablet.
Using the Kasa Lighting app you can schedule a 24/7, 365 day schedule of lighting for home and even choose to dim your lights by schedule or turn your lights out by countdown, which is great for young children or when you are leaving the house for an evening.
Currently not compatible with Amazon Echo / Echo Dot (Alexa).
Key Features
  • Low energy cost efficient LED adaptive lighting with 15 year life expectancy
  • Control up to 32 units automatically or by the touch of an iOS or Android smartphone or tablet
  • Dimmable app controlled adaptive lighting with 16 million colours to choose from
  • 24/7, 365 day app scheduling to automatically control your home lighting environment
  • Kasa scheduling countdown feature allows you to automatically turn off lights at night time or when you are leaving the home
  • Create room and mood presets to group Kasa lighting and change mood lighting to suit your environment of activity
Box Contents
  • Kasa Bluetooth Smart Lighting LED Bayonet Cap B22 Bulb
  • Quick Start Guide
  • Product Manual
Veho Kasa - LED light bulb - B22 - 7.5 W - 16 million colours
Light Source Type
LED light bulb
Socket Type
B22
Wattage
7.5 W
Wattage Equivalent
40 W
Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Luminous Power
600 lumens
Dimmable
Communications Technology
Bluetooth Low Energy (LE)
AC 100 - 245 V
Frequency Required
50/60 Hz
Light Source
LED light bulb
Socket Type
B22
Wattage
7.5 W
Wattage Equivalent
40 W
A+
16 million colours
Luminous Power
600 lumens
Dimmable
Lifetime
15000 hours
Android compatible, iOS compatible, controlled via Bluetooth 4.0 Low Energy, remote controlled
Power Requirements
AC 100 - 245 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Communications Type
Product-to-product
Diameter
60 mm
Length
112 mm
