Philips Hue 40W Lily Base and Ext.
Quicklinx: GQSGWS00 Mfr#: 919213000339
Type: Garden spot light
Compatible With: Alexa, Google Assistant, Siri
£341.65 ex VAT
£409.98 inc VAT
Extend your evenings with Philips Hue outdoor lighting. Set the right ambiance on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Energy efficient lighting
    The Philips Hue Lily features an LED light source with an energy consumption of only 8 kWh per 1000 hours, allowing for significant energy savings while providing bright and effective lighting.
  • Versatile installation
    Designed with a tilting base and a ground spike, this light can be easily adjusted and positioned to highlight features of any garden or outdoor area.
  • Weather resistant design
    Compliant with IP65 standards, this garden spot light is both waterproof and dustproof, making it suitable for various weather conditions.
  • Extensive color range
    Experience personalized lighting with 16 million color options and a color temperature range of 2000-6500 K, perfect for setting the mood in any outdoor space.
  • Smart home integration
    Compatible with the Philips Hue Bridge, this light can be easily integrated into a smart home system, allowing control via the Philips Hue app or voice commands through various intelligent assistants.
Philips Hue Lily Base and Extension Kit - garden spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 4)
Garden spot light
Recommended For
Patio
Light Source Type
LED
Packaged Quantity
4 (specifications are for single item)
Style
Functional
Cable Length
0.5 m
Wattage
8 W
Wattage Equivalent
40 W
Energy Efficiency Class
E
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
350 - 1770 lumens
Dimmable
Intelligent Assistant
Alexa, Google Assistant, Siri - indirect
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Garden spot light
Recommended For
Patio
Style
Functional
Position Adjustments
Tilting base
Cable Length
0.5 m
Waterproof
Outdoor usage, LowVolt system, remote controlled, voice control, app-controlled, interconnectable, weatherproof, ground spike, wireless dimmer switch, dustproof, waterproof, double insulated, power on/off timer, non-replaceable light bulb
Light Source
LED
Built-in LED Lamp
Wattage
8 W
Wattage Equivalent
40 W
E
Energy Consumption per 1000h
8 kWh
16 million colours
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
350 - 1770 lumens
Dimmable
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Voice Controlled
Indirect
Product Material
Aluminium
Body Colour
Power supply, ground spike, power plug
Package
Box
IP65
Warranty
2 years
7.112 cm
19.304 cm
Length
8.382 cm
3.18 kg
Dimensions & Weight Details
Ground spike height: 17.27 cm
24 cm x 31.5 cm x 22.5 cm / 4.45 kg
-20 °C
Compatible With: Siri
Brand: Philips
