- V7 Select Ultra-Slim PB17000P - power bank Li-pol
- Product Type
- Power bank
- 12.2 cm x 17.5 cm x 1.35 cm
- 538 g
- Output Connector Type
- 2 x USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Battery
- Lithium polymer 17000 mAh
- Power Device Details
- 2 x - 4 pin USB Type A - 5 V - 2.1 A
- Cables
- Micro-USB cable - 30 cm
- 1 year warranty
- Product Type
- Power bank
- 12.2 cm
- 17.5 cm
- 1.35 cm
- 538 g
- Enclosure Colour
- Dark grey
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 2 x 4 pin USB Type A
- Power Provided
- 21 Watt
- Detachable Cable Connector Type
- Micro-USB Type B
- Max Electric Current
- 4.2 A
- Smart IC chip, on/off button, LED display
- Technology
- Lithium polymer
- Capacity
- 17000 mAh
- Recharge Time
- 12 hour(s)
- Max Recharge Cycles
- 500
- Material
- Aluminium
- Cables Included
- FCC, RoHS
- Limited warranty - 1 year
