Belkin 10W Wireless Charging Pad with Micro USB Cable/No PSU - Black
Quicklinx: G5RLWS00 Mfr#: WIA001btBK
Hurry, only 1 left in stock!
£11.83 ex VAT
£14.19 inc VAT
Fast wireless charging up to 10 watts so you always safely get the fastest possible wireless charge. Just lay your phone onto the pad for a quick and easy power boost.
  • Universal QI compatibility
    Power any Qi-compatible phone using this single charger. The BOOST CHARGE wireless charging pad has been engineered to charge Apple and Samsung smartphones at the fastest possible speed while delivering 5 watts to all other Qi-enabled devices.
  • Case compatible up to 3 mm
    Charge without removing your case. BOOST CHARGE wireless charging pads are engineered to work with lightweight plastic cases up to 3 mm.
  • LED light indicates safe and successful charging
    Foreign objects like keys and coins can disrupt your charge and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence as a white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object. The light is specially designed to not disrupt the surrounding environment.
Belkin BoostCharge wireless charging pad - 10 Watt
Wireless charging pad
1.33 cm
Diameter
9 cm
74 g
Wireless Charging Standards
Qi
Power Provided
10 Watt
Cables
USB type A to micro-USB type B cable - 1.2 m
Mobile phone
1.33 cm
Diameter
9 cm
74 g
Enclosure Colour
Power Provided
10 Watt
Wireless Charging
Qi
LED indicator, FOD (Foreign Object Detection), case compatible (plastic, up to 3 mm)
Qi
Type: Wireless Charger
Brand: Belkin
