Anker 535 portable power station, portable generator 512 Wh (PowerHouse 512 Wh), 500 W 9-port outdoor generator with 4 AC outlets, 60 W USB-C PD output, LED light for camping, RV, emergencies, and more.
Long-Lasting Portable Power Station With a 10-Year Lifespan: With our proprietary long-lasting technology InfiniPowerâ„¢, combined with LiFePO4 batteries, ultra-durable electronic components, a smart temperature control system that monitors temperature up to 100 times per second, and impact-resistant structural design, Anker 535 PowerHouse is built to last over a decade, even with everyday use.
5-Year Full-Device Warranty: Instead of the average 2 years, Anker 535 Portable Power Station is designed to reliably power your devices every day for 10 years. Additionally, it offers a superior 5-year full-device warranty for a guaranteed, worry-free experience.
Extra USB-C Port: Recharge to 80% in under 2.5 hours via the in-box adapter and a USB-C port. Time to get rid of bulky adapters because charging your laptop at fast speeds only requires a single cable.
7 Ports for All: The power station has all the ports you need to charge your devices and appliances. It is equipped with 2 AC ports, 3 USB-A ports, a USB-C port, and a car outlet. -
All-Round Capacity: With a 512Wh capacity, the power station is an all-round solution to charge all your necessities. Seamlessly power a heater, portable fridge, lamp, and TV.
What You Get: Anker 535 Portable Power Station (PowerHouse 512Wh), 120W adapter, car charging cable, welcome guide, our worry-free 5-Year warranty, and friendly customer service.
Longer-lasting
Rated to provide 3000 charge cycles with premium LiFePO4 batteries extends the battery lifespan by 6x more than the standard lithium-ion battery pack. A drop-proof unibody structure enhances durability in the harshest environment for peace of mind at home or outdoors. -
Extra USB-C port
Recharge to 80% in under 2.5 hours via the in-box adapter and a USB-C port. Time to get rid of bulky adapters because charging your laptop at fast speeds only requires a single cable. -
7 ports for all
All-round capacity
With a 512 Wh capacity, the power station is an all-round solution to charge all your necessities. Seamlessly power a heater, portable fridge, lamp, and TV. -
Never lose power again
Keep everything charged and ready no matter where you are, from camping essentials to CPAP machines, and other small appliances. -
Sustainable solar charging
Harness the power of the Sun and recharge the portable power station to 80% in 3.2 hours under direct sunlight conditions. -
Quick recharge
Recharge via an in-box adapter and a USB-C port with a total output of 180 W from 0% to 80% in 2.4 hours. -
Safety first
Equipped with premium materials and an upgraded Battery Management System (BMS) that ensures complete protection for you and your devices. -
Make the most of your PowerHouse
Switching on power-saving mode enables the power station to turn off right away when your devices are fully charged. Switching off power-saving mode will enable stable charging for prolonged use scenarios. -
Keep an eye on your power
The smart LED display lets you easily track the power station's vital information such as remaining capacity, current input and output, and the time left to fully recharge the battery.
 - Anker PowerHouse 535 - portable power station - 716 Watt - LiFePO4 - 32000 mAh - 512 Wh
 - Portable power station - external
 - 7.6 kg
- Output Voltage
 - AC 220-240/ DC 5 / 9/ 12/ 15/ 20 V
- Power Capacity
 - 716 Watt
- Input Connectors
 - 2 x power DC jack, 24 pin USB-C
- Output connectors
 - 3 x 9 pin USB Type A - 5 V 2.4 A 12 W , 2 x power - 230 V 2.27 A 500 W , 1 x automobile cigarette lighter - 12 V 10 A 120 W , 1 x 24 pin USB-C 3 A 60 W
- Battery
 - Lithium iron phosphate - 32000 mAh - 512 Wh
- Included Accessories
 - Power adapter
 - 29.2 cm x 25.1 cm x 18.8 cm
 - 5-year warranty
- Input Voltage Range
 - DC 11 - 28 V / 5 / 9 / 15 / 20 V
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- Power Capacity
 - 716 Watt
- Technology
- Voltage Provided
 - 16 V
- Capacity
- Max Recharge Cycles
 - 3000
 - Power adapter
- Cables Included
 - Car power cable - external
 - LCD display, drop-resistant, LED lamp, overcurrent protection, overload protection, 60W power delivery, PowerIQ technology, PowerIQ 3.0 technology, solar panel compatible, LED display, PowerIQ 3.0, SOS mode
 - Limited warranty - 5 years
 - -20 °C
 - 40 °C
 - 29.2 cm
 - 25.1 cm
 - 18.8 cm
 - 7.6 kg
- Shipping Weight
 - 8.87 kg
