Long-Lasting Portable Power Station With a 10-Year Lifespan: With our proprietary long-lasting technology InfiniPowerâ„¢, combined with LiFePO4 batteries, ultra-durable electronic components, a smart temperature control system that monitors temperature up to 100 times per second, and impact-resistant structural design, Anker 521 PowerHouse is built to last over a decade, even with everyday use.
5-Year Full-Device Warranty: Instead of the average 2 years, Anker 521 Portable Power Station is designed to reliably power your devices every day for 10 years. Additionally, it offers a superior 5-year full-device warranty for a guaranteed, worry-free experience.
All the Ports You Need: Time to get rid of bulky adapters because charging your laptop at fast speeds only requires a single cable. See the power station recharge itself and give a high-speed charge to a wide range of devices thanks to 2 USB-A ports, an AC port, a USB-C port, and a car outlet
Huge 256Wh Capacity: The high capacity portable power station pumps out 256Wh of power—the perfect companion to charge your devices and small appliances during a weekend trip.
What You Get: Anker 521 Portable Power Station (PowerHouse 256Wh), DC adapter, car charging cable, welcome guide, our worry-free 5-year warranty, and friendly customer service.
 - Anker PowerHouse 521 - portable power station - 398 Watt - LiFePO4 - 80000 mAh - 256 Wh
 - Portable power station - external
 - 3.7 kg
- Output Voltage
 - AC 110 / DC 5 / 9 / 12 / 15 / 20 V
- Power Capacity
 - 398 Watt
- Input Connectors
 - 2 x power DC jack, 24 pin USB-C
- Output connectors
 - 2 x 4 pin USB Type A - 5 V 2.4 A 12 W , 1 x power - 110 V 1.82 A 200 W , 1 x automobile cigarette lighter 10 A 120 W , 1 x 24 pin USB-C 3 A 60 W
- Battery
 - Lithium iron phosphate - 80000 mAh - 256 Wh
- Included Accessories
 - Power adapter
 - 21.14 cm x 14.4 cm x 21.6 cm
 - 5-year warranty
- Input Voltage Range
 - DC 11 - 28 V / 5 / 9 / 15 / 20 V
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- Power Capacity
 - 398 Watt
- Technology
- Capacity
- Max Recharge Cycles
 - 3000
 - Power adapter
- Cables Included
 - Car power cable - external
 - LCD display, drop-resistant, LED lamp, overcurrent protection, overload protection, PowerIQ technology, PowerIQ 3.0 technology, solar panel compatible, LED display, PowerIQ 3.0, SOS mode
 - Limited warranty - 5 years
 - 0 °C
 - 40 °C
 - 21.14 cm
 - 14.4 cm
 - 21.6 cm
 - 3.7 kg
- Shipping Weight
 - 4.38 kg
