APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
Long battery life
APC Replacement Battery Cartridge #34 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system. -
Fully assembled for easy hot-swap installation
APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
- APC Replacement Battery Cartridge #34 - UPS battery - Lead Acid
- UPS battery
- 6 kg
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Black
- Packaging Recycled Content
- Made of recycled cardboard
- 17.4 cm x 44 cm x 4.3 cm
- 2-year warranty
- Designed For
- P/N: SUA1000RM1U, SUA1000RMI1U, SUA750RM1U, SUA750RMI1U
- UPS battery
- Battery Enclosure Type
- Internal
- Black
- Technology
- Lead Acid
- Spill-proof
Sustainability Information
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -15 °C
- Max Storage Temperature
- 45 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- 17.4 cm
- 44 cm
- 4.3 cm
- 6 kg
- Designed For
