Trust UPS 1000VA UPS PW-4100T
Quicklinx: 74HTWS00 Mfr#: 15600
Marketing description is not available.
Trust 1000VA UPS PW-4100T - UPS - 480 Watt - 1000 VA
UPS - external
6.7 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
480 Watt / 1000 VA
Input Connectors
1 x power IEC 60320
Output connectors
1 x power IEC 60320 (surge) , 2 x power IEC 60320 (UPS and surge)
Lead Acid - 9 Ah
Battery Form Factor
Internal
Run Time (Up To)
45 min
10.5 cm x 33.8 cm x 14.7 cm
UPS - external
Battery Enclosure Type
Internal
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 170 - 274 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power IEC 60320
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
480 Watt / 1000 VA
Dataline Surge Protection
Phone line - RJ-11
Surge Suppression
Surge Energy Rating
150 Joules
Circuit Protection
Fuse
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
45 min
Recharge Time
8 hours
2 x power cable - external
Equipment Protection Value
20000 Euros
Audible alarm, Automatic Voltage Regulation (AVR), LED indicators
0 - 90%
Sound Emission
40 dB
10.5 cm
33.8 cm
14.7 cm
6.7 kg
