APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks.
Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption.
Available in a variety of form factors (tower, rack mount, rack/tower convertible) there is a model for every application and budget. Smart-UPS models have long been considered the benchmark for all network and server UPS's. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery. Additional manageability options are available through the Smart-Slot interface, which is an internal slot for the installation of optional accessory cards.
Cold-start capable
Provides temporary battery power when the utility power is out. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
High online efficiency
Reduces utility costs, generates less heat. -
Intelligent Card Slot
Customize UPS capabilities with management cards. -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Sequenced network shutdown and reboot
Customize network shutdown and reboot sequence of connected servers and UPSs. -
Single switched outlet group
Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
StruxureWare Data Center Expert compatible
Enables centralized management via StruxureWare Data Center Expert. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS 2200 LCD - UPS - 1.98 kW - 2200 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 42.3 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V
- Power Capacity
- 1.98 kW / 2200 VA
- Input Connectors
- 3 x power IEC 60320 C20, power CEE 7/7, power BS 1363A
- Output connectors
- 8 x power IEC 60320 C13 , 3 x IEC jumper , 1 x power IEC 60320 C19
- Battery
- Lead Acid
- Run Time (Up To)
- 5.4 min at full load
- Networking
- RS-232, USB
- 48 cm x 68.3 cm x 8.6 cm
- 3-year warranty
- Designed For
- P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
- Height (Rack Units)
- 2U
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 299 V
- Frequency Provided
- 47 - 53 / 57 - 63 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V 47 - 53 / 57 - 63 Hz
- Power Capacity
- 1.98 kW / 2200 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 375 joules
- Technology
- Lead Acid
- Run Time (Up To)
- 5.4 min at full load , 16.1 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x USB , 1 x serial
- Expansion Slots
- 1 SmartSlot
- Cables Included
- Serial cable , USB cable , Power cable - integrated - 2 m
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR)
- C-Tick, GOST, EN 60950, GS, VDE, IEC 62040-1-1, RoHS Exemption 7b, IEC 62040-2, IRAM, WEEE
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 48 cm
- 68.3 cm
- 8.6 cm
- 42.3 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 98 cm
- Shipping Height
- 25.4 cm
- Shipping Weight
- 49.7 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.45 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £51.81 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £205.78 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £53.95 |
APC Pwr Cord, 16A, 200-240V, C19 to UK Plug | In Stock | £59.85 |
APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid | In Stock | £434.09 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £279.25 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £304.99 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £175.52 |
APC 3Yr Extended Warranty SP | In Stock | £322.47 |
APC Temperature and Humidity Sensor | In Stock | £130.54 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £53.18 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £294.10 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £70.55 |
APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m | In Stock | £151.93 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £55.08 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £58.60 |
APC Power Cable (pack of 6) 1.22m | In Stock | £90.04 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £133.11 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £103.89 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £639.92 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £765.51 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.95 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £683.92 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,274.18 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £164.46 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.56 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £466.62 |
