Trust Oxxtron 800VA UPS
Quicklinx: 9Y3BWS00 Mfr#: 17938
A lightning strike or a broken power cable can put an end to your work on the computer just like that. Prevent the loss of important data with the latest UPS security device from Trust.
A power failure can have disastrous consequences for your digital data. After hours of work at the computer, having to start all over again doesn't bear thinking about. Trust prevents this scenario with a series of new UPS devices. The new Oxxtron UPS range from Trust is an uninterrupted power supply which ensures that electronic devices don't switch off during a power failure. The Oxxtron UPS is available in four versions: 800VA, 1000VA, 1300VA and 1500VA and also protects your equipment against overload and short circuit. Connect your PC, monitor or other expensive equipment to one of the ports and you don't have to worry any more about losing data.
The 1500VA and 1300VA models of the Oxxtron have some additional features. In the event of power failure you will automatically receive an email, so that you're notified even when you're working somewhere else. Your PC is then automatically shut down safely via the USB connection. For added reliability, Trust has equipped all Oxxtron models with RFI filter, AVR function and protection of your modem, fax and telephone.
Trust Oxxtron 800VA UPS - UPS - 800 VA
UPS - external
Power Capacity
800 VA
Output connectors
2 x power (UPS and surge)
UPS - external
Power Capacity
800 VA
Surge Suppression
2 x power cable
Equipment Protection Value
20000 Euros
Audible alarm, Automatic Voltage Regulation (AVR), overload protection, short-circuit protection
