Product
Trust Oxxtron 1500VA Management UPS 1500 VA
Quicklinx: 93C1WS00 Mfr#: 17678
Type: UPS
Power Rating: 1500VA
£113.16 ex VAT
£135.79 inc VAT
Previously a lightning strike or a broken power cable can put an end to your work on your computer. Let Trust's latest UPS security device prevent the loss of important data. In the past a power failure can have disastrous consequences for your digital data. After hours of work on the computer having to start all over again doesn't bear thinking about. The Trust Oxxtron 1500VA Management UPS prevents this scenario.
The UPS becomes manageable via USB for status overview along with an added remote control monitoring system. The 1500 UPS has 4 protected outputs for PC, Monitor, and other important peripherals so protection of your system can remain paramount.
The 1500VA has many other additional features. In the event of power failure you will automatically receive an email, so that you're notified even when you're working somewhere else. Your PC is then automatically shut down safely via the USB connection. For added reliability, Trust has equipped this and all Oxxtron models with RFI filter, AVR function and protection of your modem, fax and telephone.
The new Trust Oxxtron UPS from Trust is a so-called uninterrupted power supply which ensures that electronic devices don't break down during a power failure. The Oxxtron UPS is available in three versions: 1000VA, 1300VA and 1500VA and also protects your equipment against overload and short circuit. Connect your PC, monitor or other expensive equipment to one of the ports and you don't have to worry any more about losing data.
Trust Oxxtron 1500VA Management UPS - UPS - 1500 VA
UPS - external
Power Capacity
1500 VA
Output connectors
4 x power
USB
Microsoft Windows 2000/XP/Vista/7, Microsoft Windows 2003
UPS - external
4 x power
Power Capacity
1500 VA
Dataline Surge Protection
Phone line
Surge Suppression
Remote Management Interface
USB
1 x USB
USB cable , 2 x power cable
Equipment Protection Value
20000 Euros
Audible alarm, Automatic Voltage Regulation (AVR), overload protection, short-circuit protection
Software Included
Drivers & Utilities
Type: UPS
Brand: Trust
Price Range Ex VAT: 100 - 150
