TRENDnet's Powerline 500 AV Wireless Access Point, model TPL-410AP, uses an electrical outlet to create or expand a wireless network. Two Powerline adapters are needed to start a network. Connect one adapter to a router and plug in the TPL-410AP on your electrical system to create or expand a high performance wireless network.
- TRENDnet TPL-410AP - powerline adapter - Wi-Fi - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 500 Mbps
- Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, sync button
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 6.5 cm x 7 cm x 10 cm
- 168 g
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
- Localisation
- United Kingdom
- 3-year warranty
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 500 Mbps
- Encryption Algorithm
- WPA2, 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901, FCC
- 2 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- Internal
- Gain Level
- 3 dBi
- Power Device
- Internal power supply
- Voltage Required
- 8 Watt
- Cables Included
- 1 x network cable - 1.8 m
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 6.5 cm
- 7 cm
- 10 cm
- 168 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
