TRENDnet THA-101
Home Smart Switch
 (with Wireless Extender)
TRENDnet THA-101 Home Smart Switch (with Wireless Extender)
Quicklinx: B3XZWS00 Mfr#: THA-101
  • IEEE 802.11n
TRENDnet's Home Smart Switch with Wireless Extender, model THA-101, is a combination smart electrical outlet and powerful N300 wireless extender.
Create a daily schedule to turn on/off the outlet to match your needs or to give the illusion that you're home. Place the THA-101 in an area of your home with low wireless coverage - the powerful built-in N300 wireless extender connects to your existing wireless router and broadcasts a strong wireless network.
  • Remote power control
    Turn a light, fan, electronic device, or appliance On/Off from any mobile Internet connection.
  • On/Off schedule
    Create a weekly on/off schedule for a light, fan, or another device to match your needs or to give the illusion that you're home.
  • No clutter
    The compact form factor stays off the ground by plugging directly into an outlet.
  • Power consumption
    See how much power your device is consuming with real-time electrical consumption information listed within the app.
  • Over current protection
    Trips relay when current exceeds 16 Amps.
  • Wireless extender
    Extends the range of your existing wireless network.
  • Wireless Coverage
    Extended wireless coverage with MIMO antenna technology.
  • One touch connection
    Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button.
  • LED indicators
    LED indicators convey device status.
TRENDnet THA-101 Home Smart Switch - Wi-Fi range extender - Wi-Fi
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
5.8 cm x 3.7 cm x 9.3 cm
156 g
3-year warranty
5.8 cm
3.7 cm
9.3 cm
156 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Remote Power On, remote Power Off, MIMO technology, Wi-Fi Protected Setup (WPS), integrated power socket, reset button, over-current protection, on/off switches
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
2 dBi
FCC
Internal power supply
6 Watt
Limited warranty - 3 years
0 - 95% (non-condensing)
