Zonal Color Control - make the most of 50-section addressable color zones, to suit every mood or scenario setting Extra White LEDs - act as general lights, strengthening the practicability of the colourful Wi-Fi light strip Fancy Lighting Effects - amuse yourself with well-designed animated lighting effects, available on Tapo App Music Sync - adds more vibe by emitting dynamic lights, parallel with the surrounding music beat Apple HomeKit Supported - control your light strip with Siri using Apple HomeKit Surface Coating-stays durable, tidy, and complete, thanks to the high-quality PU coating on its surface. Compatible with your smart voice assistants, including Alexa and Google Assistant Easy Setup - attach the Light Strip with 3M Adhesive on desired spots, connect it to Wi-Fi and configure it via App
Flexible design
The Tapo L930-10 light strip features a flexible design with 3M adhesive tape mounting, making it easy to install in any corner of your home for that perfect ambient lighting. -
Smart control
With Wi-Fi connectivity and compatibility with the Tapo app, Alexa, and Google Assistant, this light strip offers app-controlled and voice-controlled lighting adjustments, including dimming, color changes, and power on/off schedules. -
Vibrant lighting options
Boasting 16 million changeable colors and 50 color zones, the Tapo L930-10 allows for personalized lighting setups that can sync with your music, enhancing any entertainment experience. -
Energy-efficient illumination
Equipped with a built-in LED lamp that has a lifetime of 25,000 hours and a luminous power of 2000 lumens, this light strip provides bright, energy-efficient lighting with a quick warm-up time of 1 sec. -
Customizable settings
From lighting schedules to away modes, the Tapo L930-10 offers a range of customizable features, including cuttable sections for a tailored fit and a dimmable range from 1 to 100%, ensuring the right light for every moment.
- Tapo L930-10 - light strip - LED - 24 W - RGBW light - 2500-6500 K (pack of 2)
- Product Type
- Light strip
- Light Source Type
- LED
- Packaged Quantity
- 2 (specifications are for single item)
- Usage Modes
- Music sync, away
- Wattage
- 24 W
- Colour of Illumination
- RGBW light
- Colour Temperature
- 2500-6500 K
- Luminous Power
- 2000 lumens
- Luminous Power per Length
- 200 lumens/m
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
- Packaged Quantity
- Product Type
- Light strip
- Usage Modes
- Music sync, away
- Flexible, 3M adhesive tape mounting, cuttable, app-controlled, lighting schedules, Wi-Fi (2.4 GHz) controlled, power on/off timer, voice control, 1 - 100% dimmable, 50 colour zones, 2 strips from 1 controller
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 24 W
- RGBW light
- 2500-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 2000 lumens
- 200 lumens/m
- Warm-Up Time
- 1 sec
- Dimmable
- Lifetime
- 25000 hours
- Colour changing LED, 16 million changeable colours, RGB colour changing control, white LED
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.4 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Apple HomeKit
- Compatible Application
- Tapo app
- Supported Host Device Platform
- iOS, Android
- Wi-Fi
- Voice Controlled
- Indirect
- Product Material
- Polyurethane (PU)
- Included Accessories
- Power adapter, controller, mounting adhesive
- Package
- Box
- VCCI, BSMI, IC, FCC, RoHS, NCC, RCM, JRF, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 1 cm
- 0.3 cm
- Length
- 5 m
- -15 °C
- 40 °C
