Effortlessly set the mood in any room of your home with the unconventional, compact Philips Hue Bloom. Simply plug in to a plug socket and use the Bloom to cast colorful light as a standalone lamp or add it to your existing Hue system as an accent light.
A plug-and-play accent lamp
The Philips Hue Bloom is a small, versatile smart lamp that casts light in any of millions of colors. The Bloom's easy plug-and-play design lets you place the lamp anywhere: place it on a table to wash the walls with beautiful light, set it on your nightstand for a gentle nightlight or position it near your TV to enhance your entertainment with light.
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energise, Concentrate, Read and Relax. The two cool-toned scenes, Energise and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
Control with app or voice
Philips Hue works with Amazon Alexa, Siri and the Google Assistant. Simple voice commands let you dim, brighten or change the colour of your lights, whether you want to control a single lamp or all lights in your home. Voice control requires a Philips Hue Bridge and a compatible partner device.
Create a personalised experience with colourful smart light
Transform your home with over 16 million colours, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theatre, enhance your home decor with colour accents, and much more.
Unlock the full suite of smart lighting features with the Bridge
The Bridge unlocks the features that make smart lighting truly smart - away-from-home control, voice control, automated lighting and much more. Add a Bridge to your setup to create immersive experiences, tap into technology that's secure and reliable, and more. The Bridge is the key to smart lighting like you've never seen before.
A Plug-and-Play accent lamp
The Philips Hue Bloom is a small, versatile smart lamp that casts light in any of millions of colors. The Bloom's easy Plug-and-Play design lets you place the lamp anywhere: place it on a table to wash the walls with beautiful light, set it on your nightstand for a gentle nightlight or position it near your TV to enhance your entertainment with light. -
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Control lights with your voice
Philips Hue works with Amazon Alexa and the Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp. -
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind. -
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Create a personalized experience with colorful smart light
Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more.
- Philips Hue Bloom - desk lamp - LED - 7.1 W - 16 million colours - 2000-6500 K - white
- Product Type
- Desk lamp
- Light Source Type
- LED
- White
- Wattage
- 7.1 W
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 500 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Hue, Nest
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Desk lamp
- Remote controlled, ZigBee Light Link
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 7.1 W
- 2000-6500 K
- Luminous Power
- 500 lumens
- Lifetime
- 25000 hours
- Colour changing LED, ZigBee technology
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue, Nest
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Product Material
- Metal, plastic
- Body Colour
- White
- Included Accessories
- UK power plug
- Package
- Box
- Plug and Play, IP20
- Warranty
- 2 years
- 12.9 cm
- 10.1 cm
- Length
- 12.6 cm
- 452 g
