Hue Centura offers the perfect splash of ambiance for any occasion. Ideal for your living room and bedroom. Control via Bluetooth to instantly set light scenes in one room or pair with a Hue Bridge to unlock the full suite of features.
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Create a personalized experience with colorful smart light
Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more. -
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
 - Philips Hue White and Color Ambiance Centura - recessed spot light - LED spot light bulb - GU10 - 5.7 W - 16 million colours/warm white to cold white light - 2000-6500 K - white (pack of 3)
- Product Type
 - Recessed spot light
- Recommended For
 - Kitchen, living room, bedroom, study room, home office
- Light Source Type
- Packaged Quantity
 - 3 (specifications are for single item)
- Supported Light Bulbs Qty
 - 1
- Dimmer
 - White
- Socket Type
 - GU10
- Wattage
 - 5.7 W
- Energy Efficiency Class
 - G
- Colour of Illumination
- Colour Temperature
 - 2000-6500 K
- Luminous Power
 - 350 lumens
- Intelligent Assistant
 - Google Assistant, Alexa
- Platform
 - Hue
- Communications Technology
 - Bluetooth
- Voltage Required
 - AC 220 - 240 V
- Frequency Required
 - 50 - 60 Hz
- Packaged Quantity
- Product Type
- Recommended For
 - 1
- Dimmer
 - Double insulated, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled, voice control
Light Source
- Socket Type
 - GU10
- Wattage
 - 5.7 W
 - G
- Energy Consumption per 1000h
 - 6 kWh
 - 2000-6500 K
- Luminous Power
 - 350 lumens
- Lifetime
 - 15000 hours
Power Requirements
- Voltage Required
 - AC 220 - 240 V
 - 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
 - Philips Hue Bridge
- Platform
 - Hue
 - Bluetooth
- Product Material
 - Synthetics
- Body Colour
 - White
- Package
 - Box
 - IP20
- Warranty
 - 2 years
 - 9 cm
 - 9 cm
 - 10 cm
- Diameter
 - 9 cm
 - 198 g
- Dimensions & Weight Details
 - Hole cut-out diameter: 7 cm
- Shipping Dimensions (WxDxH) / Weight
 - 21.9 cm x 10 cm x 20.9 cm / 856 g
