TRENDnet TEW-638APB N300 Wireless Access Point
Quicklinx: 9CX2WS00 Mfr#: TEW-638APB
  • IEEE 802.11n
The versatile 300Mbps Wireless N Access Point is designed to create a scalable high speed wireless n network or to connect a wired device to an existing wireless network.
Use multiple 300Mbps Wireless N Access Points together to extend your network using Wireless Distribution System (WDS), Wireless Bridge and AP Client Modes.
Expand a wireless network without running additional cabling with Wireless Distribution Service (WDS) technology by connecting multiple access points wirelessly. Use Wireless Bridge Mode to connect devices such as game consoles, printers and digital video recorders (DVR) to your wireless network. Advanced antenna technology (MIMO) increases wireless coverage and WPA / WPA2 encryption protects your wireless network.
TRENDnet TEW 638APB - radio access point - TAA Compliant
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
12 cm x 8.8 cm x 2.6 cm
145 g
3-year warranty
Radio access point
12 cm
8.8 cm
2.6 cm
145 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DQPSK, CCK, 64 QAM, BPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz
Max Range Indoors
100 m
Max Range Open Space
300 m
Status Indicators
Power, LAN, wireless, WPS
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wireless Distribution System (WDS) support, GREENnet technology, Access Point operational mode, MIMO technology, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), wireless bridge mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
2 dBi
1 x 100Base-TX - RJ-45
1 x network cable - 0.6 m
ETSI, FCC
TAA Compliant
ENERGY STAR Certified
External power adapter
Limited warranty - 3 years
5 - 90% (non-condensing)
