The N300 Wireless PoE Access Point (model TEW-653AP) combines high speed wireless n coverage with Power over Ethernet (PoE) technology* to deliver up to 12x the speed and 4x the coverage of wireless g**.
This feature rich device blends into most environments and offers Access Point, Wireless Distribution System (WDS), and Repeater mode functionality.
Define a weekly power saving schedule, view real time network traffic charts, turn off the flashing LED indicators, and assign individual VLANs* for up to 4 separate SSIDs. Advanced antenna technology (MIMO) delivers superior range and eliminates dead spots. Synchronize wireless clients at the touch of a button with Wi-Fi Protected Setup (WPS). Advanced encryption protects valuable data and WMM® Quality of Service (QoS) technology prioritizes video and audio packets.
*Optional power port and power adapter provided for non-PoE installations.
Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and coverage will vary depending on interference, network traffic, building materials and other conditions.
*Virtual Local Area Networks (VLAN) created separately by Web Smart switches, Managed Layer 2 switches or third party
- TRENDnet TEW TEW-653AP - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 12 cm x 12 cm x 5 cm
- 280 g
- 3-year warranty
- 12 cm
- 12 cm
- 5 cm
- 280 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- Spread Spectrum Method
- OFDM
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP
- Frequency Band
- 2.4 GHz
- Selectable Channels Qty
- 13
- Status Indicators
- Power, WLAN, LAN
- VLAN support, auto-uplink (auto MDI/MDI-X), Wireless Distribution System (WDS) support, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Multiple SSID support, reset button
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
- Antenna
- Internal
- Antenna Qty
- 1
- Gain Level
- 4 dBi
- 1 x 100Base-TX - RJ-45
- Mounting Kit
- Included
- ETSI, FCC, RoHS
- PoE
- Power Device
- External power adapter
- 6 Watt
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
