TRENDnet 24-Port 10/100Mbps GREENnet Switch
Quicklinx: B4G0WS00 Mfr#: TE100-S24g
The 24-port 10/100Mbps GREENnet switch provides improved bandwidth, ease of use, and reliability, all while reducing power consumption by up to 40%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office efficiency and reduce network congestion with a total switching capacity of 4.8Gbps with full-duplex mode. Plug and play this sturdy metal rackmount switch for reliable high-speed network connectivity.
TRENDnet TE100 S24g - switch - 24 ports
Switch - 24 ports
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
24 x 10/100
MAC Address Table Size
8K entries
Flow control, full duplex capability, auto-sensing per device, MDI/MDI-X switch, auto-negotiation, GREENnet technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
44 cm x 14 cm x 4.4 cm
1.9 kg
5-year warranty
Switch - 24 ports
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
24 x 10/100
8K entries
Status Indicators
Port transmission speed, power, link/activity
24 x 100Base-TX RJ-45
Internal power supply
6.5 Watt
Plug and Play, FCC, RoHS
44 cm
14 cm
4.4 cm
1.9 kg
Limited warranty - 5 years
10 - 90%
