TRENDnet 16-port GREENnet Gigabit PoE+ Switch (250W)
Quicklinx: FQ8XWS00 Mfr#: TPE-TG160g
TRENDnet's 16-Port Gigabit PoE+ Switch offers 16 x Gigabit PoE+ ports, a 32 Gbps switching capacity, and a PoE power budget of 246 Watts. This rugged metal switch comes with a rack mount kit.
  • PoE camera flexibility
    The switch recognizes non-PoE, PoE (15.4 W), and PoE+ (30 W) cameras (or other PoE devices) and supplies the required amount of power automatically.
  • Full PoE power
    The large 246 Watt PoE power budget supplies full PoE power to every port, thereby maximizing the number of allowable connected PoE devices.
  • Gigabit networking
    All Gigabit ports produce a 32 Gbps switching capacity and support Jumbo Frames up to 10 KB.
TRENDnet TPE TG160G - switch - 16 ports - rack-mountable - TAA Compliant
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
246 W
Performance
Switching capacity: 32 Gbps , Forwarding performance (64-byte packet size): 23.8 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Half duplex mode, full duplex mode, GREENnet technology, over-current protection, short circuit protection, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
44 cm x 21 cm x 4.4 cm
3 kg
TAA Compliant
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
246 W
Performance
8K entries
Jumbo Frame Support
10KB
RAM
512 KB
Status Indicators
Status
16 x 1000Base-T RJ-45 PoE+
Internal power supply
36 Watt
Rack Mounting Kit
Included
FCC
TAA Compliant
44 cm
21 cm
4.4 cm
3 kg
Limited warranty - lifetime
0 - 90% (non-condensing)
