TRENDnet 16-Port 10/100Mbps GREENnet Switch
Quicklinx: B4G2WS00 Mfr#: TE100-S16Eg
The compact 16-Port 10/100Mbps GREENnet Switch provides improved bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 40%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management required.
Boost your office efficiency and reduce network congestion with a total switching capacity of 3.2Gbps with Full-Duplex Mode. Plug and Play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TE100 S16Eg - switch - 16 ports
Switch - 16 ports
Subtype
Fast Ethernet
Ports
16 x 10/100
MAC Address Table Size
8K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, GREENnet technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
Environmental Standards
ENERGY STAR Qualified
18.4 cm x 12.4 cm x 4.4 cm
775 g
Apple MacOS, Linux, Microsoft Windows
3-year warranty
Switch - 16 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
16 x 10/100
8K entries
Status Indicators
Port transmission speed, power, link/activity
16 x 100Base-TX RJ-45
External power adapter
6 Watt
ENERGY STAR Certified
Plug and Play, ISO 9001, FCC
18.4 cm
12.4 cm
4.4 cm
775 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
