What This Product Does
Directional Antenna TL-ANT2409A operates in the 2.4GHz band and provides 9dBi directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the RP-SMA female connector guaranteeing wider compatibility with most of the wireless equipments.
Enjoy the benefits of wireless connectivity at greater distances and throughput throughout your indoor wireless zone. No configuration or installation software required .
Easy To Use
Installation of the TL-ANT2409A is simple and straight forward. It is compatible with most wireless devices (Access Points, Routers, Bridges and Network Adapters) on the market with removable external antennas.
- TP-Link TL-ANT2409A - antenna
- Product Type
- Antenna
- 12 cm x 12 cm x 4 cm
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Outdoor, wall-mountable, pole mount, indoor
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.5 GHz
- Gain
- 9 dBi
- Directivity
- Directional
- Plug and Play, FCC, RoHS
- Product Type
- Antenna
- 12 cm
- 12 cm
- 4 cm
- Cable Length
- 1 m
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.5 GHz
- Gain
- 9 dBi
- Directivity
- Directional
- Voltage Standing Wave Ratio (VSWR)
- 1.92:1
- Horizontal Beamwidth
- 60°
- Vertical Beamwidth
- 75°
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x SMA male
- -10 °C
- 60 °C
- 10 - 90%
