TP LINK TP-Link MC200CM - fibre media converter - 1GbE
Quicklinx: 7607WS00 Mfr#: MC200CM
46 In Stock
£28.80 ex VAT
£34.56 inc VAT
The MC200CM is a media converter designed to convert 1000BASE-SX fiber to 1000Base-T copper media or vice versa. Designed under IEEE802.3ab 1000Base-T and IEEE802.3z 1000Base-SX standards, the MC200CM is designed for use with multi-mode fiber cable utilizing the SC-Type connector. The MC200CM supports shortwave (SX) laser specification at a full wire speed forwarding rate. It works at 850nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required) or with TP-LINK's 19'system chassis, Auto MDI/MDI-X for TX port, and front panel status LEDs. The MC200CM will transmit at extended fiber optic distances utilizing multi-mode fiber up to 0.55 kilometers.
  • Efficient data transfer
    With a data transfer rate of 1 Gbps, the TP-Link MC200CM V5 provides quick communication between devices, making it an ideal solution for high-speed networking.
  • Versatile connectivity options
    Featuring RJ-45 and SC multi-mode connectors, this media converter allows for flexible connections to accommodate different networking devices and configurations.
  • Robust environmental handling
    Built to operate in a range of 0°C to 40°C with humidity levels from 10% to 90%, this device is capable of functioning in a variety of environments, ensuring reliable performance.
  • Easy setup features
    With features like auto-negotiation and auto-uplink, installation and configuration of the MC200CM V5 are simple and user-friendly, reducing setup time.
  • Durable housing design
    Constructed with a metal housing, this media converter is designed to withstand various environmental conditions while maintaining its performance integrity.
TP-Link MC200CM V5 - fibre media converter - 1GbE
Fibre media converter - RJ-45 / SC multi-mode
External
Cabling Type
1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
9.45 cm x 7.3 cm x 2.7 cm
P/N: TL-MC1400, TL-SG3210XHP-M2 V2.6, TL-SG3452XP V1
External
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Status Indicators
Power, link/activity
Metal housing, auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3ab, IEEE 802.3z, IEEE 802.3x
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-SX - SC multi-mode female x 2
FCC, RoHS
External power adapter
9.45 cm
7.3 cm
2.7 cm
10 - 90%
Type: Media Converter
Brand: TP LINK
