TP LINK WLAN-Antenna 2.4GHz 8dBi Indoor Omni RP-SMA
Quicklinx: 898BWS00 Mfr#: TL-ANT2408CL
The TL-ANT2408CL 8dBi antenna is ideal for upgrading your wireless access points/routers. It is very easy to use, no configuration or software installation required.
TP-Link TL-ANT2408CL - antenna
Antenna
1.3 cm 29.4 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Indoor
Compatibility
802.11 b/g/n
Frequency Range
2.4 - 2.4835 GHz
Gain
8 dBi
Directivity
Omni-directional
RoHS
Antenna
1.3 cm
29.4 cm
Enclosure Colour
Aerial
Intended For
Wi-Fi
Indoor
Compatibility
802.11 b/g/n
Frequency Range
2.4 - 2.4835 GHz
Gain
8 dBi
Directivity
Omni-directional
Voltage Standing Wave Ratio (VSWR)
1.92:1
Horizontal Beamwidth
360°
Vertical Beamwidth
15°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x RP-SMA female
RoHS
-10 °C
60 °C
10 - 90%
