Directional Antenna TL-ANT2409B operates in the 2.4GHz band and provides 9dBi directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the N female connector guaranteeing wider compatibility with most of the wireless equipment's. Also, the weather proof design ensures that it can work normally for various demanding outdoor solutions.
Enjoy the benefits of wireless connectivity at greater distances and throughput throughout your outdoor wireless zone. No configuration or installation software required.
Highlights:
* 9dBi directional operation provides extended point to point connection or indoor and outdoor area coverage
* Features 100cm CFD-200 low loss cable for flexible deployment
* N female connector, works with most of access points / wireless routers
* Provides easy installation mounting kits
Easy To Use
Installation of the TL-ANT2409B is simple and straight forward. It is compatible with most wireless devices (Access Points, Routers, Bridges and Network Adapters) on the market with removable external antennas.
Box Contains
9dBi Panel Directional Antenna
Installation mounting kits
User Guide
- TP-Link TL-ANT2409B - antenna
- Product Type
- Antenna
- 12 cm x 12 cm x 4 cm
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Outdoor, wall-mountable, pole mount
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.5 GHz
- Gain
- 9 dBi
- Directivity
- Directional
- FCC, RoHS
- Product Type
- Antenna
- 12 cm
- 12 cm
- 4 cm
- Cable Length
- 1 m
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.5 GHz
- Gain
- 9 dBi
- Directivity
- Directional
- Voltage Standing Wave Ratio (VSWR)
- 1.92:1
- Horizontal Beamwidth
- 60°
- Vertical Beamwidth
- 75°
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x N-Series connector female
- FCC, RoHS
- -10 °C
- 60 °C
- 10 - 90%
