Working in conjunction with 4ipnet WHG controllers, this 4ipnet access point extends business-class WLAN security and management capabilities in enterprise or industrial environments.
- 4ipnet EAP300 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 22 cm x 12.7 cm x 3.3 cm
- 0.82 kg
- 22 cm
- 12.7 cm
- 3.3 cm
- 0.82 kg
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
- Spread Spectrum Method
- OFDM, DSSS
- DHCP, DNS
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP
- Frequency Band
- 2.4 GHz, 5 GHz
- Selectable Channels Qty
- 14
- Status Indicators
- Power, WLAN, LAN
- DHCP support, power over Ethernet (PoE), VLAN support, repeating mode, Syslog support, DiffServ support, manageable, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, wireless bridge mode
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, AES-CCMP, WPA2-PSK
- Authentication Method
- RADIUS, Extended Service Set ID (ESSID), Extensible Authentication Protocol (EAP)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.11f
Aerial
- Antenna
- External detachable
- Antenna Qty
- 3
- 1 x 1000Base-T - RJ-45 , 1 x management - DB-9 , 1 x USB
- FCC, RoHS, IEC 60529 IP50
- PoE
- Power Device
- External power adapter
- -30 °C
- 70 °C
- 10 - 80% (non-condensing)
