Manage the lighting at your fingertips to create the perfect atmosphere in your home at any time with the Tapo L510E smart Wi-Fi lightbulb.
Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
Create a regular schedule to turn on/off with the brightness you set and automatically activate your light according to your time zone.
Manage the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant. Take your phone out for the pocket and open the Tapo app to control your light remotely. Tapo L510E allows you to automatically simulate someone being at home to frighten away unwanted visitors.
Dimmable (Adjust with Ease)
Dimmable (Preset for Convenience)
Schedule (Set Your Times)
Schedule (Sunrise and Sunset Modes)
Automatically activate your light according to your time zone
Voice Control
Mange the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant
Remote Control
Away Mode
Automatically simulate someone being at home to frighten away unwanted visitors
Adjust with ease
Manage the lighting at your fingertips to create the perfect atmosphere in your home at any time. -
Preset for convenience
Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights. -
Set your times
Create a regular schedule to turn on/off with the brightness you set. -
Sunrise and sunset modes
Automatically activate your light according to your time zone. -
Voice control
Mange the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant. -
Remote control
Take your phone out for the pocket and open the Tapo app to control your light remotely. -
Away mode
Automatically simulate someone being at home to frighten away unwanted visitors.
- Tapo L510E - LED light bulb - E27 - 8.7 W - 2700 K (pack of 2)
- Light Source Type
- LED light bulb
- Packaged Quantity
- 2 (specifications are for single item)
- Usage Modes
- Sunrise, sunset, away
- Socket Type
- E27
- Wattage
- 8.7 W
- Colour Temperature
- 2700 K
- Luminous Power
- 806 lumens
- Beam Angle
- 220 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Tapo
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Packaged Quantity
- Usage Modes
Light Source
- LED light bulb
- Socket Type
- E27
- Wattage
- 8.7 W
- Energy Consumption per 1000h
- 8.7 kWh
- Lamp Current
- 73 mA
- 2700 K
- Colour Rendering Index
- 80
- Luminous Power
- 806 lumens
- Beam Angle
- 220 degree(s)
- Warm-Up Time
- 1 sec
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 15000
- Voice control, controlled via Wi-Fi, remote controlled, light scheduling, app-controlled, adjustable colour temperature, Wi-Fi (2.4 GHz) controlled, away mode
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Tapo
- Compatible Application
- Tapo app
- Wi-Fi
- RoHS, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Diameter
- 60 mm
- Length
- 115 mm
