Zonal Color Control - make the most of 50-section addressable color zones, to suit every mood or scenario setting.
Extra White LEDs - acts as general lights, strengthening the practicability of the colorful Wi-Fi light strip.
Fancy Lighting Effects - amuse yourself with well-designed animated lighting effects, available on Tapo App.
Music Sync - adds more vibe by emitting dynamic lights, parallel with the surrounding music beat.
Apple HomeKit Supported - control your light strip with Siri using Apple HomeKit.
Voice Control- compatible with your smart voice assistants, including Alexa and Google Assistant.
Surface Coating-stays durable, tidy, and complete, thanks to the high-quality PU coating on its surface.
Wi-Fi Connection - with a stable connection to your networks, it works well without hub requirements.
Easy Setup - attach the Light Strip with 3M Adhesive on desired spots, connect it to Wi-Fi and configure it via App.
1000 lumens white light for illumination
Extraly-added white LED light beads, spanning over the light strip, emit high-lumen white lighting. It makes Tapo L930-5 an all-rounder, serving diverse illumination purposes. -
50 color segments for zonal control
Exert your imagination to set the 50 separate color zones or let it shine to suit your changing moods. -
Crystal, flexible, and clean
Tapo L930-5, generates a soft transparent light through its exterior PU coating. It's easy to attach it as the way you want. The high-tech coating protects all the LED beads well and makes it easy to maintain. -
Stir your sense up via music sync
L930-5 light strip captures the music going around it, syncing to the frequency and the beat. Keep pace with the rhythm and get all your senses stirred up at a party!
- Tapo L930-5 - light strip - LED - 13 W - 16 million colours
- Product Type
- Light strip
- Light Source Type
- LED
- Usage Modes
- Away
- Wattage
- 13 W
- Colour of Illumination
- Luminous Power
- 1000 lumens
- Dimmable
- Intelligent Assistant
- Alexa, Google Assistant, Siri - indirect
- Platform
- Apple HomeKit
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
- Product Type
- Light strip
- Usage Modes
- Away
- 50 colour zones, cuttable, 3M adhesive tape mounting, power on/off timer, lighting schedules, remote controlled, app-controlled, voice control, flexible, Wi-Fi (2.4 GHz) controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 13 W
- Luminous Power
- 1000 lumens
- Dimmable
- Lifetime
- 50000 hours
- Preset modes, 1%-100% dimmable, music sync, white LED
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Apple HomeKit
- Compatible Application
- Tapo app
- Wi-Fi
- Voice Controlled
- Indirect
- Product Material
- Polyurethane (PU)
- RoHS, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, JRF, IC, VCCI, RCM, NCC, BSMI
- 1 cm
- 0.3 cm
- Length
- 5 m
- 649 g
- Shipping Dimensions (WxDxH) / Weight
- 23.15 cm x 6.85 cm x 20.45 cm
- -15 °C
- 40 °C
TP LINK Tapo L930-5 Smart Light Strip - 5mtrs
