TP LINK Tapo L920-5 Light strip  LED 13.5W 16 million colour
Quicklinx: GLJWWS00 Mfr#: Tapo L920-5
Type: Light strip
Compatible With: Alexa, Google Assistant
15 In Stock
£25.83 ex VAT
£30.99 inc VAT
Multiple Color & Effects - Control 50 separate color zones and bring vibrant joy to your life.
External Protection – Easy maintenance and extended lifespan thanks to PU coating.
No Hub Required - Connect to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Flexible Installation - Cut it to whatever length you want and attach it to any surface with the 3Madhesive.
Preset for Convenience - Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
Schedule & Timer - Create schedules and count plans to turn on/off with the brightness/color you set.
Away Mode - Simulate someone being at home to frighten away, unwanted visitors.
Connect It Your Way - Use it with your smart assistant, a hub, or connect directly to the Tapo App. Control the Light Strip however you want.
Voice Control - Use simple voice commands to control your light strip with Alexa or Google Assistant.
  • Wonderful lighting effects
    Pick from a variety of animated effects for a unique lighting experience. Multicolor LEDs allow you to create your own ambiance in tons of fun colors and levels of brightness.
  • Smart lighting controls
    Schedule your light strip for effortless automation. Combine it with other Tapo devices for seamless control, especially when you're sprucing up your home with consistent lighting.
  • 16 different color zones
    Have the lights match your mood, with different color zones to fill the room with lights the way you want it.
  • Made for everyday wear and tear
    The strip's durable PU coating prevents moisture and dust intrusion and electrical leaks.
  • No hub required
    Connect to your home's secure Wi-Fi network. No need for a hub or extra equipment.
  • Sync-to-Sound
    Bounce to the beat of your favorite tunes. Coordinate the vibrant colors to your songs and fill your life with energy.
  • Flexible installation
    Cut it to whatever length you want and attach it to any surface with an adhesive.
  • Away mode
  • Preset for convenience
  • Schedule and timer
    Create schedules and count plans to turn on off with the brightness color you set.
  • Connect it your way
    Use it with your smart assistant, a hub, or connect directly to the Tapo App. Control the light strip however you want.
  • Voice control
  • Wind down at night
    Install the light strip to relax your body and mind through a mood-setting atmosphere.
Tapo L920-5 - light strip - LED - 13.5 W - 16 million colours
Light strip
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2516797
Light Source Type
LED
Usage Modes
Away
Wattage
13.5 W
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Dimmable
Intelligent Assistant
Alexa, Google Assistant - indirect
Platform
Apple HomeKit
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Light strip
Usage Modes
Away
Cuttable, 3M adhesive tape mounting, lighting schedules, power on/off timer, remote controlled, app-controlled, Sync-to-Sound function
Light Source
LED
Built-in LED Lamp
Wattage
13.5 W
G
Energy Consumption per 1000h
4 kWh
16 million colours
Dimmable
Lifetime
50000 hours
1%-100% dimmable, colour changing LED
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.4 watt
Internet of Things (IoT)
Hub
Not needed
Platform
Apple HomeKit
Compatible Application
Tapo app
Wi-Fi
Voice Controlled
Indirect
Power adapter
RoHS
1 cm
0.16 cm
Length
5 m
57 g
14.45 cm x 6.85 cm x 11.95 cm
-15 °C
Type: Light strip
Brand: TP LINK
