TP LINK Tapo L510B Dimmable Smart Light Bulb B22
Quicklinx: FTNGWS00 Mfr#: Tapo L510B
Type: Light bulb
Compatible With: Alexa, Google Assistant
23 In Stock
£6.66 ex VAT
£7.99 inc VAT
The whole room is dark when you get off from work at night, then you need to fumble around to find the light switch. With L510B and the Tapo app, you just need to take your smart phone out from pocket and open Tapo app, then everything is on. Worried about the house when your family is on a trip? This is where Tapo L510B Dimmable Lights functions. It turns on/off the lights randomly to simulate someone being at home. Connect the L510B Light to your home Wi-Fi network, then you are all set. No need for extra hubs or other devices.
  • Remote control
    Instantly turn the light on/off wherever you are through the Tapo app.
  • Schedule
    Preset a schedule to automatically manage devices.
  • Timer
    Create countdown timer lists for connected electronics.
  • Voice control
    Manage your smart bulb with voice commands via Amazon Alexa or the Google Assistant.
  • Away mode
    Automatically turns bulb on and off at different times to give the appearance that someone is home.
  • Easy setup and use
    No hub required, set up quickly and manage easily through the free app.
  • Device sharing
    Easily share management permissions with each member of your family.
  • Sunrise and sunset mode
    Automatically activate your bulb according to your time zone.
  • Energy saving
    Reduce energy use up to 85% without losing brightness or quality.
Tapo L510B - LED light bulb - B22 - 8.7 W - 2700 K
Light Source Type
LED light bulb
Usage Modes
Sunrise, sunset, away
Socket Type
B22
Wattage
8.7 W
Energy Efficiency Class
F
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Tapo
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Usage Modes
Light Source
LED light bulb
Socket Type
B22
Wattage
8.7 W
F
Energy Consumption per 1000h
9 kWh
Lamp Current
73 mA
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Dimmable
Delay timer, remote controlled, light scheduling
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.14 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Tapo
Compatible Application
Tapo app
Wi-Fi
Voice Controlled
Indirect
RoHS, RCM
Type: Light bulb
Brand: TP LINK
