TP LINK TL-SL2452 48-Port 10/100Mbps + 4-Port Gigabit Smart Switch
Quicklinx: 9PMVWS00 Mfr#: TL-SL2452
TP-LINK smart switch TL-SL2452 is equipped with 48 10/100Mbps RJ45 ports, 2 10/100/1000Mbps RJ45 ports and 2 Gigabit SFP slots. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK Smart Switch TL-SL2452 is a cost-effective product solution for the small and medium business. TL-SL2452 has useful security features. The Storm Control feature protects against Broadcast, Multicast and Unknown unicast Storm. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch and gigabit capability, TP-LINK smart switch TL-SL2452 provides you the ideal access-edge solution.
Advanced QoS features
To integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including Port Priority, 802.1P Priority and DSCP Priority, to ensure that voice and video are always clear, smooth and jitter free. In conjunction with the Voice VLAN the switch supports, the voice applications will operate with much smoother performance.
Abundant Layer 2 features
For more application of layer 2 switches, TL-SL2452 supports a complete lineup of layer 2 features, including 802.1Q tag VLAN, Port Isolation, Port Mirroring, STP/RSTP/MSTP, Link Aggregation Group and 802.3x Flow Control function. Any more, the switches provide advanced features for network maintenance such as Loop Back Detection, Cable Diagnostics and IGMP Snooping. IGMP snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling&filtering restrict each subscriber on a port level to prevent unauthorized multicast access.
Enterprise Level Management Features
TL-SL2452 is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface(GUI) or SNMP (v1/2/3) and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
  • Smart features
    The auto features of this switch make installation plug & play and hassle-free. Auto-MDI/MDI-X crossover on all ports eliminates the need for crossover cables for connection to another switch or hub. Auto-negotiation on each port senses the link speed of a network device (either 10 or 100 or 1000) and intelligently adjusts for compatibility and optimal performance. The TL-SL2452WEB also features diagnostic LEDs, which display status and activity, allowing you to quickly detect and correct problems on the network. It features a non-blocking wire-speed architecture with an 17.6Gbps switching capacity for maximum data throughput. With wire-speed filtering and store-and-forward switching, the web-smart switch also maximizes network performance while minimizing the propagation of bad network packets.
  • Excellent QoS performance
    Businesses are recognizing the benefits of doing Voice over IP (VoIP) and are quickly migrating their voice services to IP based platforms, requiring their local area networks to support both voice and data applications. In unmanaged IP networks, burst data sessions can disrupt voice packet delivery, causing poor voice quality. With the enhanced QoS and traffic management features in the TL-SL2452WEB, voice data can be prioritized, ensuring clear and reliable voice communications.
  • IEEE 802.1Q VLAN tagging and MTU VLAN supported
    Network security is a top priority in any size business. VLANs allow the network to be segmented into groups (departmental, hierarchical, and security groups). It enhances the security of a network. 802.1Q is a standard that places a "tag" in a frame identifying which VLAN it belongs to. The advantage of this is that all 802.1Q compliant devices can work seamlessly together to manage VLAN traffic. In addition, MTU VLAN enables each user port and the uplink port in the same VLAN.
TP-Link Web Smart Switch TL-SL2452WEB - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x SFP + 2 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
HTTP
Auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, manageable, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, VCT technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
44 cm x 26 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8K entries
HTTP
Status Indicators
Power, 100M device connected, system, 1000M device connected, link/activity
48 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
FCC
44 cm
26 cm
4.4 cm
10 - 90%
9PMV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
9PMV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
