TP LINK 5-Port Gigabit Desktop Switch With 4-Port PoE+
Quicklinx: FZ6PWS00 Mfr#: TL-SG1005LP
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
More than 50 In Stock
£29.00 ex VAT
£34.80 inc VAT
TL-SG1005LP is a professional 5-port Gigabit switch with 4 PoE+ ports. The total 40 W PoE power budget for the four PoE ports opens up a wide range of applications, such as surveillance for offices, dormitories, and small businesses. It is fully compatible with IP cameras, access points, IP phones, computers, printers, and more. The interior components of TL-SG1005LP are protected by high-quality metal casing to ensure a long product life.
  • Dedicated 4-port PoE+ switch (40 W budget) for numerous applications
  • Intelligent power management
    When total power consumption exceeds 40 W, the intelligent power management will cut the lower priority port power. This ensures the high priority port's power supply and protects the device from power overload. It also automatically detects and provides the required power for your PoE devices while protecting your PoE and non-PoE equipment from being damaged.
  • Qos for fluent online experience
    Administrators can designate the priority of traffic based on QoS, for example, to ensure that voice and video applications remain clear and lag-free.
  • IGMP snooping - traffic optimization for IPTV
    IGMP Snooping optimizes multimedia traffic delivery, to ensure a better network experience especially for applications like IPTV.
  • Durable metal casing
    The interior components of TL-SG1005LP are protected by high-quality metal casing to ensure a long product life. Having passed an array of stringent reliability tests, TL-SG1005LP delivers switching performance you can depend on.
TP-Link TL-SG1005LP - V1 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000 (4 PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
40 W
Performance
Packet forwarding rate: 7.44 Mpps , Switching capacity: 10 Gbps
MAC Address Table Size
2K entries
Jumbo Frame Support
16KB
Routing Protocol
IGMP
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, QoS, fanless, DSCP support
IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
9.98 cm x 9.8 cm x 2.5 cm
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
40 W
Performance
2K entries
Jumbo Frame Support
16KB
Routing Protocol
IGMP
5 x 1000Base-T RJ-45 4 ports (PoE+) - 30 W
External power adapter
Power Provided
DC 53.5 V - 0.81 A
47.5 Watt
Plug and Play, FCC, RoHS
9.98 cm
9.8 cm
2.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 5
Managed: No
POE: PoE+
Brand: TP LINK
