Remote Control
Instantly turn the light on/off wherever you are through the Tapo app.
Voice Control
Manage your switch with voice commands via Amazon Alexa or the Google Assistant.
Schedule
Preset a schedule to automatically manage devices.
Away Mode
Automatically turn the light on and off at different times to give the appearance that someone is home.
Tool-Free Battery Replacement
Easily replace batteries after installation, no need of other tools.
No Neutral Wire Required
Super easy wiring. No neutral wire required.
Hub Required
The Tapo Hub is required to support all smart features.
Enhanced Experience with Smart Actions
With Smart Acitons, your Tapo devices work seamlessly together to create a smarter home. Trigger your switch when motion is detected with the Tapo Motion Sensor.
Part of the Tapo Ecosystem
To experience the full features of your Tapo, connect it to a Tapo Hub (H100) for a truly connected home. Group lights and devices onto one switch to control the entire room with a single tap.
Smart connectivity
The Tapo S210 V1 is compatible with various IoT devices and can be controlled via the Tapo app, providing users with remote access to their lighting system from anywhere. -
Energy efficient
Designed to work with a maximum load of 50 W, this light switch is suitable for different lighting setups, ensuring efficient power consumption across various lamp types. -
Easy installation
The battery-powered design eliminates the need for complex wiring, making installation simple and hassle-free while maintaining consistent performance.
- Tapo S210 V1 - light switch - smart
- Product Type
- Light switch
- Gangs Qty
- 1
- Functions
- Light control
- Power Source
- Battery
- Internet of Things (IoT) Platform
- Tapo
- Intelligent Assistant
- Alexa, Google Assistant - indirect
- Connectivity
- Wireless
- Frequency Band
- 868 MHz
- 2-year warranty
- 8.6 cm x 4.1 cm x 8.71 cm
- Product Type
- Light switch
- Functions
- Light control
- Gangs Qty
- 1
- Power Source
- Battery
- Lamp Compatibility
- Compact Fluorescent Lamp (CFL), Fluorescent Tube Light (FTL), incandescent lamp, LED lamp
- Maximum Loads
- LED lamp - 600 W , Compact fluorescent lamp - 600 W , Incandescent lamp - 1000 W , Fluorescent tube light - 1000 W , Fan - 50 W
- Connectivity Technology
- Wireless
- Frequency Band
- 868 MHz
- 1-way switch, remote access, voice control, schedule function, Away Mode, timer, no neutral required, low-battery reminder
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Tapo Hub
- Compatible Application
- Tapo app
- Platform
- Tapo
- Voice Controlled
- Indirect
- Form Factor
- AAA / LR03
- Battery Included
- Required Qty
- 2
- Voltage Provided
- 1.5 V
- Battery Lifetime
- 1 year
- Included Accessories
- 2 AAA batteries, 2 mounting screws
- Warranty
- 2-year warranty
- RoHS, UKCA
- 8.6 cm
- 4.1 cm
- 8.71 cm
- 0 °C
- 40 °C
- 10 - 90% RH (non-condensing)
