Kasa Smart Light Bulb, Multicolor
Multicolor
With a wide range of colors and dimming capabilities, Kasa Smart’s multicolor light bulb offers endless lighting possibilities. You can choose a light for everything from a dinner party to a late-night study session.
No Hub Required
Kasa Smart’s multicolor light bulb connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere
Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Dim, turn on or off or change the colors of your light bulb remotely at your fingertips.
Voice Control
Use simple voice commands to control your Kasa Smart multicolor light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Have your voice assistant change the color to help you wake up in the morning or adjust the brightness to help your kids settle down in the evening.
Auto White
Set your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
Scenes and Schedules
Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
Energy Consumption Class A+
Kasa Smart's multicolor light bulb is certified to drive down energy consumption without losing quality.
                No hub requiredKasa Smart's multicolor light bulb connects to your home's secure Wi-Fi network. No need for a hub or extra equipment.
                Control from anywhereControl your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Dim, turn on or off or change the colors of your light bulb remotely at your fingertips.
                Auto whiteSet your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
                Scenes and schedulesUse your Kasa Smart app to schedule your light bulb to automatically switch on and off when you're home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
- TP-Link Kasa Smart KL130B - LED light bulb
- Light Bulb Type
- LED light bulb
- Shape
- A60
- Socket Type
- B22
- Wattage
- 10 W
- Wattage Equivalent
- 60 W
- Light Bulb Energy Efficiency Class
- A+
- Colour of Illumination
- Multicolour light
- Colour Temperature
- 2500-9000 K
- Luminous Power
- 800 lumens
- Beam Angle
- 230 degree(s)
- Dimmable
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Warranty
- 2 year warranty
Light Bulb
- LED light bulb
- Shape
- A60
- Socket Type
- B22
- Wattage
- 10 W
- 60 W
- A+
- Multicolour light
- 2500-9000 K
- Luminous Power
- 800 lumens
- Beam Angle
- 230 degree(s)
- Dimmable
- Colour changing LED, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Internet of Things (IoT) Hub
- Not needed
- Platform
- Kasa
- Communications Type
- Cloud
- Communications Technology
- Wi-Fi
- Intelligent Assistant Compatible
- Cortana, Google Assistant, Alexa
- RoHS, SAA, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 121 mm
- Diameter
- 60 mm
- 138 g
- -15 °C
- 40 °C
