16 Million Colours -Shape the amazing vibe by picking the lights from a wide array of colours, even dim to any brightness you desire for the perfect atmosphere.
White Tuneable - Adjust the colour temperature from 2,200 K to 6,500 K based on your changing needs.
High Lumen & Dimmable - Emits 350 lm light that is bright enough to shed lights on any object and could be dimmed from 1% to 100%.
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App.
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your smart spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup and Use - No hub required, set up quickly and manage easily through the free App
                Efficient energy useWith an energy efficiency class of E and consuming only 4 kWh per 1000 hours, this light bulb is designed for energy savings and efficiency, making it an eco-friendly choice for your home.
                Versatile color optionsOffering 16 million colors and tunable white light, this bulb can adjust from a warm 2200 K to a cool 6500 K color temperature, allowing you to create the perfect ambiance for any occasion.
                Smart controlEquipped with Smart Wi-Fi technology, this bulb can be controlled via the Tapo app, with features like lighting schedules, power on/off timer, and remote control, providing convenience and customization at your fingertips.
                Voice activationCompatible with Alexa and Google Assistant, this bulb allows for voice control, enabling you to adjust lighting with simple voice commands for a seamless smart home experience.
                Long-lasting and reliableDesigned for durability, the bulb boasts a lifetime of 15,000 hours and 15,000 switch cycles, ensuring long-lasting reliability and reducing the need for frequent replacements.
- Tapo L630 - LED spot light bulb - GU10 - 3.7 W - 16 million colours/tunable white - 2200-6500 K (pack of 2)
- Light Source Type
- Packaged Quantity
- 2 (specifications are for single item)
- Usage Modes
- Energy save
- Socket Type
- GU10
- Wattage
- 3.7 W
- Wattage Equivalent
- 50 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Packaged Quantity
- Usage Modes
- Energy save
Light Source
- Socket Type
- GU10
- Wattage
- 3.7 W
- 50 W
- E
- Energy Consumption per 1000h
- 4 kWh
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Warm-Up Time
- 1 sec
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 15000
- 10%-100% dimmable, voice control, remote controlled, lighting schedules, power on/off timer, Wi-Fi (2.4 GHz) controlled, Smart Wi-Fi technology
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.2 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Compatible Application
- Tapo app
- Voice Controlled
- Indirect
- RoHS, ERP, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 5.52 cm
- Diameter
- 5 cm
- Shipping Dimensions (WxDxH) / Weight
- 55 g
- 0 °C
- 40 °C
