Extra Bright Smart Light Bulb - With 1055 lumens (75W Equivalent) of crisp, high-quality lighting, Tapo L535E is ideal for any home space requiring brighter lighting Millions of Colours - Easily design scenarios for your daily routine or activities by customizing the light brightness, light temperature, and colours–with millions of hues to choose from via the Tapo app Voice Control - Manage your smart lights with voice commands via Alexa, Siri, or Google Assistant Matter-Certified - With support for the Matter protocol, Tapo L535E can seamlessly interoperate with other certified products across platforms Schedule and Timer - Create a regular schedule to turn on/off with your chosen light effects Voice Control - Manage your smart lights with voice commands via Alexa, Siri, or Google Assistant Remote Control and Away Mode - Instantly turn connected devices on/off wherever you are via the Tapo app. Turn on away mode to simulate someone being at home Energy Monitoring - Monitor your connected devices' real-time power consumption and costs via the Tapo app No Hub Required - Connect directly to your home's secure Wi-Fi network—no need for a hub or extra equipment
                Effortless controlWith the integration of Smart Wi-Fi technology and compatibility with the Tapo app, controlling your home lighting has never been easier. Adjust brightness, change colors, and set schedules, all from the convenience of your smartphone.
                Voice activationEnhance your smart home experience with voice-controlled convenience. Compatible with Alexa and Google Assistant, this light bulb allows for easy voice commands, making it simple to adjust settings without lifting a finger.
                Vibrant illuminationExperience lighting like never before with 16 million colors and a wide color temperature range of 2500-6500 K. Whether you're setting the mood or need optimal light for tasks, this bulb adapts to your needs.
                Energy efficientDesigned with an energy efficiency class of E and consuming only 9 kWh per 1000h, this LED light bulb is an eco-friendly choice that doesn't compromise on performance. Enjoy a luminous power of 1100 lumens with just 8.6 W of energy use.
                Long-lasting durabilityWith a lifetime of 25,000 hours and 15,000 switch cycles, this bulb is built to last. Its quick warm-up time of 1 sec ensures immediate brightness, providing convenience and reliability in your home lighting.
- Tapo Smart L535E - LED light bulb - shape: A60 / A19 - E27 - 8.6 W - 16 million colours - 2500-6500 K
- Recommended For
- Home
- Light Source Type
- LED light bulb
- Usage Modes
- Away
- Shape
- A60 / A19
- Socket Type
- E27
- Wattage
- 8.6 W
- Wattage Equivalent
- 75 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Colour Temperature
- 2500-6500 K
- Luminous Power
- 1100 lumens
- Beam Angle
- 220 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Tapo, Matter
- Communications Technology
- Wi-Fi
- Voltage Required
- 220 - 240 V
- Frequency Required
- 50/60 Hz
- Recommended For
- Home
- Usage Modes
- Away
Light Source
- LED light bulb
- Shape
- A60 / A19
- Socket Type
- E27
- Wattage
- 8.6 W
- 75 W
- E
- Energy Consumption per 1000h
- 9 kWh
- 2500-6500 K
- Colour Rendering Index
- 90
- Luminous Power
- 1100 lumens
- Beam Angle
- 220 degree(s)
- Warm-Up Time
- 1 sec
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 15000
- Voice control, light scheduling, app-controlled, remote controlled, Smart Wi-Fi technology, multicolour
Power Requirements
- Voltage Required
- 220 - 240 V
- 50/60 Hz
- 9.5 Watt
- Power Consumption Stand by
- 0.2 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Tapo, Matter
- Compatible Application
- Tapo app
- Wi-Fi
- Voice Controlled
- Indirect
- Package
- Box
- FCC, ETL, DOE, CEC, RCM, SAA, ERP, UKCA
- Diameter
- 60 mm
- Length
- 115 mm
- 65 g
- -15 °C
- 40 °C
