TP LINK T3700G-28TQ  JetStream 28-Port Gigabit Stackable L3 Managed
Quicklinx: B0QJWS00 Mfr#: T3700G-28TQ
TP-LINK's T3700G-28TQ is an L3 managed switch designed to build a highly accessible, scalable, and robust network. The switch is equipped with 24 Gigabit RJ-45 ports, 4 Combo Gigabit SFP and up to 4 10Gbps SFP slots, giving network administrator great network flexibility.
It supports abundant Layer 3 routing protocols such as RIP and OSPF which are a critical part in the creation of fully resilient scalable networks. What's more, with physical stacking feature and optional redundant external power unit, T3700G-28TQ provides a robust network with efficient redundancy.
T3700G-28TQ provides robust security to help secure your enterprise network.
TP-LINK's T3700G-28TQ L3 managed switch provides a reliable and cost-effective solution for enterprise, campus and ISP networks.
  • Robust security
    Equipped with RADIUS and Secure Shell (SSH) authentication methods alongside SSL and TLS encryption algorithms, this switch ensures secure network access and data transmission.
  • High performance
    With a switching capacity of 128 Gbps and forwarding performance up to 95.2 Mpps, the TP-Link JetStream T3700G-28TQ meets the demands of high-bandwidth applications.
  • Advanced networking
    Supports Layer 3 advanced switching, Quality of Service (QoS), and various routing protocols including OSPFv2 and RIP, making it ideal for complex network architectures.
  • Versatile connectivity
    Features 24 10/100/1000 ports, 4 combo Gigabit SFP ports, and 2 10 Gigabit SFP+ ports, providing flexible connection options for a wide range of devices.
  • Efficient management
    Manageable via CLI, HTTP, and SNMP among others, this switch offers comprehensive remote management capabilities for efficient network administration.
TP-Link JetStream T3700G-28TQ - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x combo Gigabit SFP + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 128 Gbps , Forwarding performance: up to 95.2 Mpps
IP router interfaces: 128 , Static routes: 256 , Virtual interfaces (VLANs): 4000
MAC Address Table Size
32K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
RIP-1, RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, ECMP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2, CLI
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, PIM-SM snooping, MSTP support, DHCP snooping, ACL support, QoS, Jumbo Frames support, DHCP server, LACP support, LLDP support, DHCP relay, LACP, GVRP, dual firmware images, NDP, PIM-DM snooping
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s
44 cm x 33 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7, Windows 8
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), RADIUS
Built-in Devices
Led panel
Status Indicators
Power, system, RPS (Redundant Power Supply), link/activity
24 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP , 2 x 10Gbit LAN SFP+ , 1 x console RJ-45 management
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Power Provided
150 watt
63 watt
Redundant Power System (RPS) connector
4 rubber feet
Rack Mounting Kit
Included
FCC, RoHS
Software Included
Drivers & Utilities
44 cm
33 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
