TP LINK RE205 AC750 Wi-Fi Range Extender
Quicklinx: FT80WS00 Mfr#: RE205
  • IEEE 802.11n
Tired of Wi-Fi dead zones in your home The RE205 Range Extender connects to your Wi-Fi router wirelessly, strengthening and expanding its signal into areas it can't reach on its own, while reducing signal interference to ensure reliable Wi-Fi coverage throughout your home or office.
The RE205 lets you keep more devices connected at the same time with its 2.4GHz 300Mbps and 5GHz 433Mbps dual bands. Use the 2.4GHz band to send email and browse the web, and the 5GHz band for gaming and HD streaming.
  • Easily expand your Wi-Fi coverage
  • High-speed dual band Wi-Fi for better connections
  • Built-in access point mode
    RE205 is more than a wireless range extender. Simply plug the Ethernet cable into its Ethernet port to easily turn your wired internet connection into a dual band wireless access point.
  • Easy management and remote control
    The RE205 works with all Wi-Fi routers. You can use TP-Link's free Tether app to set up the range extender from any Android or iOS device in minutes. This feature-rich phone app allows you to enjoy not only hassle-free installation, but also access to advanced network management, all at your fingertips.
TP-Link RE205 - Wi-Fi range extender - Wi-Fi 5
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
7.8 cm x 8 cm x 7.7 cm
7.8 cm
8 cm
7.7 cm
External
Wireless
Data Transfer Rate
750 Mbps
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AC750
Status Indicators
Signal strength
Manageable, Access Point operational mode, firmware upgradable, Wi-Fi Protected Setup (WPS), reset button, wireless extender mode, WPA encryption, wireless SSID
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 100Base-TX - RJ-45
1 x network cable
FCC, RoHS
Internal power supply
7.3 watt
Limited warranty - parts and labour - 2 years
10 - 90% (non-condensing)
