TP LINK Omada OC300 Hardware Controller
Quicklinx: G6WKWS00 Mfr#: OC300
OC300, the hardware controller for the Omada Software Defined Networking (SDN) platform, provides 100% centralized management of access points, switches, and gateways - all controlled from a single interface.
  • Reliable performance
    Powered by a Cortex-A72 processor with a clock speed of 1.2 GHz, ensuring efficient processing and rapid response times for network tasks.
  • Extensive storage
    Includes 8 GB of flash memory that enables effective storage and management of applications and configurations.
  • High capacity management
    Supports a maximum of 50,000 clients and up to 15,000 accounts, ideal for large environments needing robust network management.
  • Enhanced security features
    Equipped with multiple security features like VPN support, MAC address authentication, and DoS attack prevention, safeguarding network integrity.
  • Versatile connectivity
    Offers various data link protocols including Fast Ethernet and Gigabit Ethernet for flexible network connectivity options.
TP-Link Omada OC300 - network management device - cloud-managed
Network management device
Rack-mountable
1 x Cortex-A72 1.2 GHz
RAM
2 GB
Flash Memory
8 GB
Maximum number of clients: up to 15000 , Manageable access points: up to 500 , Maximum number of accounts: 1000 , Maximum number of vouchers: 50000 , Maximum number of WLAN groups: 500
Rack mount kit
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 10
AC 100/240 V (50/60 Hz)
29.4 cm x 18 cm x 4.4 cm
29.4 cm
18 cm
4.4 cm
Processor / Memory / Storage
Processors Installed
RAM
2 GB DDR4 SDRAM
Flash Memory
8 GB
Rack-mountable
Wired
Network / Transport Protocol
PPTP, L2TP, IPSec, DDNS
Remote Management Protocol
SNMP, SSH, RADIUS
Cloud-Managed
Status Indicators
Power, cloud
Routing, NAT support, VPN support, DoS attack prevention, URL filtering, firmware upgradable, Access Control List (ACL) support, reset button, Captive Portal, metal housing, event notification, MAC address authentication, schedule reboot, layer 3 management, security slot (Kensington security lock compatible)
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.1x
2 x 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A
Rack mount kit
1 x network cable
FCC, RoHS
Internal power supply
14.8 Watt
50 °C
10 - 90% (non-condensing)
